2006 B3 large prop shaft seal
scoflaw
Ensign
Just removed my props for the season and had a bunch of fishing line that damaged the white plastic part of the seal. No water in oil.
​Is it possible to R&R this seal with the slide hammer technique like an outboard ?
No, that seal is a bear to remove even with the shaft removed.
scoflaw
Ensign
What is it? Metal on metal ? What's the purpose of the white plastic ring on the seal ? Really don't want to pull the drive apart, especially when it's not leaking...yet
Not seeing what you have, if it was just a bit of plastic missing and no leaks I would just leave it be and keep close eye on it.
scoflaw
Ensign
More than a bit. The plastic ring broke off nice and clean. Be nice to be able to stick another piece of plastic on there. Apparently no line cutter available for this drive.
​I can see how the next time I pick up line it will be damaging to the sealing area
