2006 D215 Sanger Mid-Engine Slow Leak
B-D215
Hello,
I have a 2006 Sanger D215 which seems to have started taking on a bit more water the last couple years. I've checked all the hoses and engine plugs and they seem fine.
It takes on water while just sitting on the buoy so I'm thinking maybe it's something lose around the prop? I was told to look at the shaft seal or rudder port but I'm not sure how to see those in the mid engine boat.
If anyone has any ideas where the water might be coming from or knows how to see the areas I mentioned that would be really really helpful : )
Thanks!
As others have mentioned its most likely the prop shaft seal. Look online for a bore scope type camera that connects to your phone. You can then get it tighter places to look
