Something that doesn't work and then mysteriously works is cause for concern as that mystery repair may come back to bite you when you leaste expect it -- like miles from the ramp!I suggest you really look into this further.
Thanks, but I wouldn’t have said it now mysteriously works? We spent a fair bit of time eliminating a bunch of potential reasons, and the conclusion we came to was that It seemed that there was either a Vacuum in the Fuel Line, or there was something stuck inside the Fuel Pump. The Boat had been sitting a while, and was running 100% when last used. We haven’t field tested it yet, but it’s running as well as ever now in the tank. Will be field testing it tomorrow on the lake, not too far from land, with Oars on hand
Someone else suggested checking the Anti-Siphon Valve? But this hadn’t come up as a potential issue from the symptoms we were experiencing.
Cheers
