shackle101
Thread starter- Joined
- Jan 11, 2012
- 140
So I got a couple questions on the winterizing of this setup.
With the MPI engine do you still spray fogger under the flame arrestor? Also any suggestions for putting in new plugs with the Tahoe 215 space seems very limited any useful tools that may help?
As for antifreezing the lower unit I got a tank off amazon for it and had a few questions with that.
1. Do you run the water while running the antifreeze as well or do you shut off the water valve completely when running the antifreeze in?
2. Do you need to drain after applying antifeeze with the turn valve or do you leave the antifreeze in the block?
I'm changing the fuel filter, foot oil, greasing, and engine oil/filter. Any other tips feel free to share as inboards are pretty new to me.
Thanks!
Thanks!
