Can or does this switch activate a guardian mode on this motor.? Can a bad switchbox keep the oil pressure light illuminated ? When started the light will illuminate for the 5 or so seconds then go off. It then comes back on and will stay on whether idling or throttled up.. I did check that there is good oil flow although I did not check the actuall pressure . I will try that today if I can get hold of a tester of sort.
