2007 Chris Craft Launch 22 w/ 5.0 Volvo Penta - continuous beep alarm
07CCLaunch22
Hello,
I have a 2007 Chris Craft Launch 22 with a Volvo Penta 5.0 GXi.
The boat had been sitting since the summer of 2007 due to particular reasons. I had it winterized (fogged etc.) that winter of 2007, and without using it at all I had it winterized again in the winter of 2008.
So for the first time in about a year and a half I launched it today, drove it to its dock and it ran fine. It started right up from the launch and everything went perfect.
After driving it in I checked the oil and after just changing the oil, it was a little low so it took a quart to be totally full.
A few hours later I took it out to dinner and while pulling out I felt the drive hit something. It is very shallow and it was most likely sand that it hit considering the drive was all the way down, but possibly a small rock, but on the way there it ran fine and I feel this incident has nothing to do with the main issue.
After about an hour and a half, we began heading back. I remember while starting the engine, it hesitated and I had to hold the key longer then usual.
Then after about 3 minutes a loud half a second beeping noise came on. We turned the engine off and sat there then turned it back on. Three minutes went by and it started again. After getting out of the no wake zone (with it beeping), we tried gunning it and it definitely hesitated.
All the gauges were fine (temp, oil pressure, voltage etc.).
Finally we got back.
After considering the situation, I thought maybe: the injectors are clogged, (mainly because it ran fine while idling, but when given more gas, it would not go), bad gas (?), or maybe while sitting, some type of wires were chewed by mice.
I do not have the manual with me hence I cannot look up the meaning of that beep, but after hearing everything, what do you think this could be?
A on a side note, boat has been always used in fresh water (Lake George, NY) hence no possibilities of corrosion, rust etc.
I am anxious to get home and check the manual.
Thanks for your help.
Joe
caperman
Re: 2007 Chris Craft Launch 22 w/ 5.0 Volvo Penta - continuous beep alarm
look for grass on the back of the prop and check your drive oil resevoir tank make sure u got oil in it
caperman
last summer i had grass around my prop no speed and off balance
07CCLaunch22
Good idea. I had a boat in salt water once (Sea Ray 280) and same thing happened to me (grass and barnacles on out drive).
Do you think that when I hit something while pulling out, it could have sprung a leak of drive oil?
Joe
caperman
see if the oil tank is down and see if the prop as any damage to it
i hit mine and put a small hole in it and lost some drive oil
07CCLaunch22
Ok, will do.
Considering this boat only has 14 hours on it, it must be something like that.
Joe
caperman
check your skeg then u will know how hard u hit
AZSenza
Its the thin aluminum "Fin" that sticks out under the prop. Its supposed to help in directional stability and protect the prop from hits (It should hit first depending on prop size)
07CCLaunch22
Ya just checked the outdrive this morning, everything looks fine.
Have come to the conclusion that it might be some type of knock sensor which could be disconnected and is causing the motor to go in limp-home mode (only revs to a certain RPM).
Joe
mia248vista
Joe
did you ever solve this problem?
