2007 e-tec 250 lower mount corrosion
darrklim2
I took off the cover and removed the mount. There are holes in all 3 sides of the midsection where the mount goes in.
Is this useable for a while?
I know that replacing the midsection is best but not in the budget right now.
Crosbyman
depending on how solid the rest is....
Call me cheap but.....if money is short and won't buy the parts you need and we are all faced with these decisions at one point...... you call always patch it up with the stronger automotive fiberglass imbedded car putty and noboby will tell the difference after a good sand job and some spray paint job.
on very small holes or sections JB weld does a good job if you need to drill and tap ...delicately !
FB works on cars in much worse condition ! you can use the light duty putty on the last cover coat for easier sanding.
wash and brush off all the corrosion you can (use salt-away if you want or hot vinegar) a pre-coat of yellow chromate spray paint may help.
start adding gradual layers of putty to build upon (scratch each successive layer as you build up to ensure a better grab) ....on larger holes apply a backing for the first layer .
if not accessible insert a small piece of "whatever".. held by a string you can pull it shut while the FB hardens in a minute or two .... work fast !!!
up the creek...... that is what I would do. to keep me going for a while anyway . jmho !
Crosbyman
well I looked at the parts listing and ETEC manual...it could be a lost cause but hey! faced with a 3K$ job try FB a heavy layer if you have to ... the stuff is prettty stong and... won't corrode anymore :)
Chris1956
Generally, midsections do not corrode like that. Actually, after the gearcases and powerheads go bad, they are the only remaining parts in good shape. You might look for a used midsection at the usual salvage yards and online. Yours looks too far gone to be epoxied back to life.
saltchuckmatt
Almost looks like freeze and corrosion issues, but yikes.
I had an 09.... and I'm SaltChuckMatt so....
darrklim2
According to a parts lookup the midsections he has for sale should match.
I didn't get a response to a message that I sent on the forum. I haven't texted yet though.
For now I put in a new used rubber mount and new used cover and ran it last weekend.
It works but I will plan to replace the midsection when I can.
