2007 honda bf40a tach problem
shero144
I bought Honda #06300-ZW5-000KT Tach/Trim kit. All harness wires clearly marked and colors match up. FARIA(#TC9163D) Tach shows 3k at idle on recommended pole setting #1 and is erratic on all other settings. FARIA tells me that I need TACH ADAPTER HARNESS(Jumper Kit) Honda#32197-ZH8-003 which connects negative charge coil to the tach sending wire. Can anyone tell me exactly where this jumper is installed on the engine? I have the Honda shop manual including wiring diagrams.
Thanks, Bill
JB
Re: 2007 honda bf40a tach problem
You will get much better response in the Honda forum, shero.
I will move this for you.
