Hi Folks - so after I figured out the diagnostics port I was able to run the software and faultcodes are tripping. The Diacom software doesn't seem to list the specific part, but lists some info the sensors are picking up it looks like. Looks like it's reading the lake temp at 426 degrees. I've changed the engine block temp sensor and the mechanic I originally had taken it to had said it was the expensive air intake sensor reading high. I reset the fault codes and still the same fault is tripping again. Engine is off sitting in my garage and has been for a week. Is there another temp sensor? Or something else completely?
There seem to be different "modules" that store this data too. The fault is always tripping for the "FUEL LVL CKT HI" section. I don't have a manual yet so not sure what that means if anything.
Current ECM Codes
Misc Fault, click Read Fault button for details
Freeze Frame Data:
0 FUEL LVL CKT HI
FF Baro Pressure 14.16 PSI
FF Battery Volts 12.33 VDC
FF Sea Pump Pressure 0.00 PSI
FF Boat Speed 0.00 #
FF Manifold Air Temp 68.00 ?F
FF Coolant Temp 64.40 ?F
FF Demand 0.16 %
FF Engine Speed 0 RPM
FF Engine State Stall
FF FPC Total 0.0 Counts
FF Frequency Count 1
FF Fuel Level 0.00 %
FF Gear Position Neutral
FF Lake Temp 426.20 ?F
FF Engine Load 0.00 %
FF Main Pwr Relay Requests NO
FF Manifold Air Pressure 14.18 PSI
FF Oil Level 0.00 %
FF Port Tab Pos 0.00 %
FF Available Power 10 %
FF Run Time 337.67 hrs
FF Starboard Tab Pos 0.00 %
FF TPS Percent 0.16 %
FF Trim Position 100.00 %
Thanks,
Marc
Current ECM Codes
Freeze Frame Data:
0 FUEL LVL CKT HI
FF Demand 0.16 %
FF Oil Level 0.00 %
Thanks,
Marc
