2007 Pathfinder factory tow issue
nichollb
Hey here is what I have going on.
07 pathfinder tow harness factory installed 4 pin plug turn and brake lights not working.
The running lights are fine. But no power at the 4 pin factory plug for my L and R turn/brake lights?
Hooked up my borther truck and the trailor is not the problem all lights turn, brake, running work.
Just to really make sure I hooked up my Pathfinder to diff trailor same issue.
Checked all the fuses under the hood.
Is it possiable that there a seprate fuse some where just for the turn/brake. I assume it is all or nothing?
Anyone have same issues? Any ideas would be great.
(Factory tow package I guess I should have hooked something up before the warranty expired)
Lrider
Re: 2007 Pathfinder factory tow issue
tow lights are simple, get under the car and trace the wires to where they plug in, the car is factory prewired for a plug in harness. if all is well there I might suggest the cheapest way is wire it the old fashion way, might take you 20 minute :)
OldNBold51
I've an 05 Pathfinder and developed turn issues recently on my trailers. The electrical's are kinda complex for our vehicle.
http://www.thenissanpath.com/filelib/R51/Service/fwd.pdf
is the manual. I'm pretty sure my issue is in the BCM under the dash. I haven't fixed it yet. I'm only missing left turn right now so I'm living with it.
