2007 SX A Volvo Penta Removal
dgs119
Does anyone have step by step instructions and tips on how to remove my 2007 VP SX-A outdrive? I can't find anything on youtube or online. Pics or video would help a ton. I wan to pull it to do the annual check of bellows, grease splin and look for any leaks.
Any help would be great!
cr2k
Re: 2007 SX A Volvo Penta Removal
Put it in N and pull the 6 bolts on the back.
dgs119
Is it really that simple? I have never done it and just want to make sure I do it correctly.
Don S
No, it's not quite that simple, he only left out removing the back cover, then disconnecting the shift cable and trim cylinders.
Here is a link to the OEM service manual. Might want to look it over so you do the job correctly. Makes sure you grease the proper places before installing the drive back on the boat.
http://www.4shared.com/file/107267155/55b98c32/7746477_SX-A_DPS-A.html
dgs119
Don thank you so much!!! This will help a ton. You wouldn't happen to have a link to the shop manual for the engine? 2007 4.3 (GM?) red in color on a Four Winns H190.
