Black Snow Slide
Thread starter- Joined
- Jun 15, 2007
- 276
2007 Volvo 5.7 Cooling Problem DP-SK drive. Sealed cooling system with a heat exchanger
I am stumped as well as 5 other friends who have many years of boating. Boat fresh from winter storage. I installed a new raw water impeller. OEM part, same part number and side by side exactly the same. In stalled with a new rubber seal. (Yes I took out the old) cap on, sealed down. Useing muffs that are tight around the intakes good water pressure. Water flows when started but after about 5 minutes it will not draw water through. If I rev it up, will help but still not as good as the old one.
Trouble shooting: I took off the exit hose ( the bottom one ) and started it again. No water exiting the pump when motor is running.
I took off the raw water intake hose and hooked up a shop vac to it. Sealed it around the hose and turned the Vac on. Outside very strong suction at the out drive. I then turned the vac from sucking to blowing and good flow of air at outdrive.
Any ideas? I cant figure this one.
