2008 115 hp 4S 4 beep warning signal.
Water logged
On Saturday after a high speed run I got a 4 beep warning. It was 4 beeps every couple minutes until I beached and shut down. could not restart battery was dead. Checked the manual and determined the 4 beeps indicated the battery was dead. Well that was dead on. Simple enough, new battery. Ran about 3 hours on Sat with new battery. Ran 3 to 4 hours on Sunday tried another high speed run as soon as I throttled down got the 4 beeps. Got a multi meter and the battery showed just over 12 volts. Ran just a short time today and as soon as I tried to speed up it started beeping again. Battery still shows btwn 12 and 13 volts. Any suggestions on where to start the healing?
Glenn
ryanskeeter
Re: 2008 115 hp 4S 4 beep warning signal.
Glenn
i am not a mechanic so i could be wrong but my older merc did this to me when it was having oil delivery problems you might could research that but i will continue to watch this thread to see the outcome i would like to know as well
Don S
Start the motor and run it up to about 1200 to 1500 rpm and see what the voltage is on the battery using a DVM on the battery itself, not the helm instrument.
BCguy1395
It may be that the fusible link has been blown and the alternator, although working cannot charge the battery. It happened on my 2006 115HP Optimax
1nebel0
[/I]
I totally agree with Don....run a volt meter and you should see 13.8-14.5 or so...less than that and you got alternator issues....battery must be fully charged...
Water logged
It was the 100 amp fuse on the feed line out of the alternator. Not a replaceable fuse, had to replace the whole line. None available in Lake Havasu City, or the immediate area. On order will be in by ??????????.
Glenn
