TBarCYa
Thread starter- Joined
- Apr 13, 2005
- 781
A couple weeks ago I found an oil leak that turned out to be from the lifter cover. I ordered the gasket, took everything apart (to find that there's no gasket just form-a-gasket) and put it back together with new sealant and everything from an oil perspective is okie dokie.
Last weekend we took her out and she was a little hard to start and after heading out thru the channel finally got to open her up and she had no power. Would not even get up on plane unless I had everyone move to the front then she wouldn't turn more than 3000rpms.
The day before heading out, I filled the tank in my truck with regular and the boat with mid grade (which is a mix of regular and premium for those that don't know) and she sat overnight. I have never put gas from this particular station in the boat before but a friend uses it almost exclusively.
I asked my friend if he ever had problems with the gas there and he said that he has not and asked if I have a water separating fuel filter, which I do not. I have recently (3 months) moved to Florida (Homestead) from New Jersey and have never had any fuel issues but I'm told that a filter is pretty much required in Florida due to condensation in fuel tanks.
I'm going to install the fuel filter regardless but my question is does this sound like a water-in-the-fuel issue? It definitely seems like a fuel issue to me which is why my first thought was bad gas.
Along the same lines, in order to do the cover gasket, I had to remove the distributor. I marked the 4 plug wires and marked where the rotor was pointing on the cap housing before removing it. Since the rotor was pointing at the mark and the cap is oriented pretty much where it was, I thought I had the timing where it belonged but if not, how far off would the timing have to be in order to cause these symptoms? I'm going to try to rent a timing light to set it but there's no balancer on the engine just the pulley on the front near the timing indicator so I'm not sure where the timing mark may be on the pulley. I assume it has to be there somewhere or else I'm somehow not seeing a harmonic balancer on the front of the engine.
Anybody that can help would be greatly appreciated.
