2008/4.3/ no fire?
Blk-n-Blu
Master Chief Petty Officer
Re: 2008/4.3/ no fire?
Gray is for the tach and goes on the -Neg side
horsefly38425
New coil still no fire at spark plugs/ what are the 3 wires comeing out of the dist? one red+white/ one green+white/ one black. where should i have 12 volts on these
Don S
Do you have your safety kill switch lanyard hooked up?
Can we assume you have a carbed engine?
horsefly38425
engine turns over/ just no spark. would a bad safety switch cause it? it is on run. yes it is carbed eng. have jump wired it yet. ran fine when i put it up last winter.
Don S
Sure a bad safety switch would cause it. What it does is stops power from the ignitions switch from getting to the coil. it could also be a bad ignition switch, or a corroded terminal somewhere.
With the key in the run position check to see if you have power to the purple wire on the coils + terminal.
jbrentscott
Thanks for the reply/help. Let me add to this, its my boat that we're talking about here, HF38425 is helping me with it. We have checked/eliminated the kill switch as problem since the purple wire to coil has 12v when key is on and kill switch is in "run" when you turn the kill switch off it cuts the 12v to the coil so we thought the eliminated the kill switch/ignition. That right?
Don S
Here's a troubleshooting chart that should get you started in the right direction.
attachment.php
