2008 Chaparral Signature 310 Trailering
Mcguiver
I saw a post where someone was asking if the radar arch could be lowered/tilted for trailering but he didn't get a reply, only assumptions & guesses. Has anyone had any experience with it?
I'm also looking for dimension of the boat to order a trailer. Does anyone have these dimensions or know where I could locate that information?
briangcc
Umm....over 10' beam right? That's overwidth/overwide in my state meaning permits and most likely escort vehicles to get that on the road....let alone a vehicle capable enough of pulling it.
Mcguiver
Mcguiver
I checked the requirements for each state we plan to trailer it and 10'7" beam doesn't trigger having an escort for width. Just need a permit, "Over Size Load" banners and corner flags during day light and corner lights after dark.
My main concern with the boat I'm purchasing is the height because it has a radar with anchor light that adds an additional height of approximately 2" and there's speakers mounted on the radar arch so wanting to hear from anyone who has lowered/tilted their radar arch to trailer their boat in lea of removing & reinstalling the speakers, anchor light & radar off every time we go anywhere. If I didn't lower the arch or remove speakers & radar, it would require escort for exceeding the height. However, even if the planned route for permitted loads says the bridge clearance is adequate, power lines droop over time and their height isn't documented/checked often, so I'm trying to get the height down as much as possible.
Murphy's law - if something bad could happen it'll happen to me.
Thanks for the reply!
Most have the radar arch removed for transport
tpenfield
You might try the Chappy forum or Chaparral themselves for the trailer dimensions. Odds are that a trailer does not have to be exact and it will still fit OK.
My boat is 10' 10" wide and sits at 12' (to the arch) on the trailer.
Mcguiver
For whatever reason Chaparral decided to increase the radar arch height on this model 310, making the bridge clearance 11' 2" so adding 22" for height on the trailer plus accounting for draft gets it over the 13' 6" legal height for highways (W/O the radar or speakers attached).
Earl Cordova
That forum is absolutely worthless. That is why I ended up here.
And I know from experience that if you ask the factory a trailer question
they will advise you to contact your dealer.
tpenfield
I have trailering dimensions for my Cruisers 338 and the keel to the arch is 10' 5" . . . sitting on the trailer the top of the arch was 12' 0". So, on the trailer the keel is about 1' 7" off the ground.
I would expect the boat (Chap 310) to be under 13' sitting on an appropriately fitted trailer. Often the arch on the boats can be unfastened and lowered for travel.
Mcguiver
We bought the boat but haven't removed the arch or put it on the trailer yet, but it will exceed the height limit. Does anyone have the Signature 310 with the factory installed hinged arch option and willing to share photos with it tilted to see if mine can be retrofitted if they still sell the hinges?
your local Chap dealer can get that information from the Chap customer service department
Mcguiver
Thanks Scott, spoke with him about 30 minutes and wasn't too reassuring the parts would be available given the year and fact that this was an option so I probably going to have to try to reproduce something and it would be terrific if I could see the internals of the radar arch base to know how it was configured.
Mcguiver
FYI - if anyone was wondering if were possible to retrofit the arch with a hinge (without having to purchase original parts), I succeeded in doing it for <$300 and all you need is access to a table saw & handheld grinder. It isn't motorized but 2 people can raise or lower it OR 1 with the aid of a portable gantry lift system (<$75 and you can purchase everything at the hardware store or "big box" lumber store.
Mcguiver
thanks for the update . . . Got any pictures to share?
Unfortunately I didn't document it as it progressed. Going stay on the boat this weekend so I'll get a few pictures of what it looks like with the arch up so check back over the weekend. If I can remember, I'll take pictures of it folded down but it may be a while before I need to do that. When its folded, you can see the hinge & lugs that keeps the arch from moving while the arch is up as well as where the pin engages into the arch & lugs.
Mcguiver
20250223_120226.jpgHere are a few pictures of the finished product with the arch up. The arch is made of pipe rolled into shape then filled it with sheet aluminum which is welded to the pipe so its fairly thick at the pivot point. There's an aluminum base plate so I used a cutting dish on a grinder to cut a notch wide enough for 1/2" thick T-6061 aluminum bar stock to make part of the hinge and the notch in the arch makes up the remainder of the hinge. I had to cut the notch in the arch high enough to allow the arch to pivot down. I used a grinding disk to round out the end of the 1/2" bar stock and "toe" of the arch so it wouldn't bind when pivoting. The hinge bolt is 1/2" stainless steel with an acorn nut. The rear of the arch is pinned with a 1/2" stainless pin that has a spring loaded ball. I'll have to post pictures at a later date of the underside whenever I fold it down.
Mcguiver
Here's what the underside of the arch base looks like so you can see what the pin engages into. The slots cut in the base of the arch and aluminum blocks they engage with are a snug fit to minimize movement. I used the existing bolt hole in the hu.
Mcguiver
Here's my rigging to lift or lower the arch. It's just a 2X4 with a 2X6 base to provide a high anchor point. Two ropes aft attach to the cleats and the one on the dash hand bar is just to hold it in place until my block & tackle are hooked up. I made a box to rest the arch on when its lowered and padded it with carpet.
Earl Cordova
Our local Chaparral dealer, who we ordered our boat through,
did absolutely nothing to help us with our trailer problems.
Maybe that attitude is why they lost their Chaparral franchise a few years later.
