2008 Master Craft X2 Wiring
2008X2
I have a Master Craft X2 with Forward facing tower lights that dont work. Does any have, or know where i can get, wiring schematics for these tower lights
Silvertip
Re: 2008 Master Craft X2 Wiring
You don't need one. If none of them work, check the fuse(s). If they are ok, check for 12 volts on the line side of the switch. If not present, determine why. Power comes from the fuse so if the fuse is good the problem is between the fuse and the switch. If there is 12 volts at the switch turn it on and check at the load side. If 12 volts is not present the switch is bad. If it is present the problem is between the switch and lights or the lights have lost their ground.
seabob4
On an '08, I doubt the switches or breakers have gone south. MC uses good s***. X2, are you comfortable with a multimeter? If not, here's a good tutorial...The Multimeter.
2008X2
I don't think I stated my problem right there is No wires on the back of the switch for the forward tower lights at all like they forgot to put them on. the tower light come down but have no where to go. like i am missing wires. i need to know which wires are what coming off the tower so i can run new wire
seabob4
So who did you buy this MC from? Are the lights on the tower factory? Is the tower factory? I'd call MC and ask them what the deal is. Have your HIN ready, they'll have the file there in CS.
