- Joined
- Jul 23, 2011
- 53,456
Run from a portable tank. If it runs better, look at your fuel in the tank
temp was within specs, 154 degrees , warmed up according to the scan toolAny thoughts as to the engine not coming up to temp or the ECM is not seeing the correct temp and limiting fuel?
i did that on saturday as noted in post 11. the boat does finally get up on plane and ive had it up to around 42-4400 rpms, but very sluggish getting there, i ran the boat on the external tank and it sucked down a gallon of fuel,. i changed back to the boats tank and it continues to run the same,Run from a portable tank. If it runs better, look at your fuel in the tank
