2009 Mercruiser 3.0L TKS stalling
spunkyman
He y’all. Have an 09 Bayliner with the 3.0L Mercruiser - it has the TKS carb. Fires up amd runs for a bit then stalls. I took the carb apart, stripped it (except for the little “T”, spring and ball and the accelerator pump looked fine), soaked it, replaced all the needed parts in my kit and put her back on. She fired right up and ran for almost a minute ! Then, stalled and had to juice her hard to get her to fire again… bogged down and mostly unhappy that ended with a puff of smoke coming out the flame arrester 💨… could it be that the enrichment valve is shot ? Or before unloading $400 on that, is there something else that would stop this thing from purring like a kitten 🐱? She just won’t idle. Thx in advance.
Check your fuel delivery system. Fuel filter contents in clear container. Disconnect power to coil and remove fuel line. Crank motor and see how fuel comes out, a little or a lot.
spunkyman
I also noticed it’s flooding. Gas coming right up that main throttle shoot … readjusted float and needle/seat…. that seemed to have fixed it. I’ll take it to the water and see ! Thx Dodge !
