2009 Nissan-Tohatsu 15 upgrade to 18/20 Guru?
JimXeod
Was wondering if you can do a simple carb swap on a 2009 15hp to upgrade to a 20hp? Anything else? How much should this run if possible?
Thanks!
JimXeod
Re: 2009 Nissan-Tohatsu 15 upgrade to 18/20 Guru?
I would say C? It's a 2009 351cc. Same dispalcement as the 18 and 20, that is why I am curious.
JimXeod
So is that the same as the current mercury 15 and 20's? (they don't have an 18) Can the Tohatsu-Nissan Carb be interchanged with a Merc 20 carb?
TOHATSU GURU
Tohatsu does not have an 4-stroke 18 either...The carburetor is the same, however, the linkage points may be different to accommodate the placement of the Mercury throttle and choke hardware.
Boisegolfer
I have seen different approaches printed in Forums, this one and:
Replace the jets with 20c jets and remove the restrictor plate.
Will both accomplish the same thing?
Sea Rider
You could do just jet swaps and remove restrictor plate, but you don't know if the 20 model has wider interior gas passages for better performance than the 15 carb ?
Happy Boating
jrs_diesel
Happy Boating
Same thing as the 4/5/6 engine family. You have to swap the carb to get the 6 HP because of the internal passages being different sizes.
pvanv
No. It's a different venturi size. And there isn't any restrictor plate. You need the correct carb. Swapping out jets will make the motor run like crap -- if at all -- because the mixture will be way wrong.
Question:
I do have the 2007 B2 15hp Tohatsu model (MFS15B2) and it has the same displacement 351cc and same weight as the 20hp model.
Can i upgrade to 20hp and how?
Thanks.
