2009 regal 2000 rx 220 hp mpi
Alkibar
i have a 20 foot regal rx fasttrack 220 hp 4.3l mpi
The boat had a changed prop when I bought it
Im over 200lb and want it for wakeboarding what prop should I be purchasing
I found a 14 inch 19 pitch AL 4 blade
Will that be better than the loaner I have now 14 in 19 p ss 3 blade witch wot at 4400 rpm to 4500 rpm or should I go to 17 or 18 pitch
Scott06
I would drop down to a 17 or 18 if going from 3 to 4 blades assuming your tach is accurate (might be worth a sanity check with a shop tach). For watersports I had good luck with michigan votex 4 blades and its a cheap whay to cut your teeth on prop swapping .
What SS 3 blade is the loaner? Manufacturer and type.
