Knockerjoe
Thread starter- Joined
- Nov 13, 2002
- 38
Hi, I have a 94 200hp Johnson Ocean Pro. The starter pinion will not engage sometimes. This problem has been intermitant since I bought the boat 3 years ago. Here is what i have done so far:<br />Went from a single battery with no battery switch to a dual battery with perko switch. <br />Replaced all battery cables. Cables run a long distance because of bracket. Used 2 gauge wire.<br />Relaced starter solenoid.<br />Removed starter and cleaned and lubed pinion shaft.<br />Hooked up jumper power pack directly to starter and does not repeat, started works strong.<br />I still have the same problem and it has been getting worse.<br />Usually it happens on the first start in the morning. Pinion will not engage for 2 or 3 turns of the key than will engage. Then will engage for most of the day sometimes repeating.<br />Any suggestions will be appreciated!
