ondarvr
Thread starter- Joined
- Apr 6, 2005
- 11,527
1976 200hp Evinrude<br /><br />I was told by an old OMC mechanic that all I needed to do to time this motor was disconect the spark control arm and with the motor running at an idle, move the spark control to the WOT stop. is this accurate, with no load, no throttle and not at 5000 rpm, it was 26 BTDC using this method.<br /><br />The Seloc manual says it should be 28 BTDC, the sticker on the motor says 26. Which one is correct.<br /><br />Thanks
