200mer
Spain
2004 200hp mer want power up an plain off. I have replaced fuel,sparkpluges,primer bub,fuel lines, low prussure fuel pump,fuel filter,cleand and tested high pressure pump its at 37lb,cleand and tested injectors. Did a cold eng compression check show 97 lb all cil. Still blogs willnot take off. Only three times while checking it in water after doing work on it,it did power up and run for a short time.
Faztbullet
How did you test injectors? What is fuel pressure with engine running?
Spain
Tested injectors removed from eng. Plug each into air line with fuel and 10lb prussure open indectors with 1.5v . Fuel prusser is 37lb on water hose at 1000 rpm no load though
