toybuilder039
- Joined
- Mar 6, 2011
- 84
Cylinder 2 is firing 2 and 4 its never fired on 6. I may have said 4 and 6 on first post.
But I agree I was hoping it would follow
Whatever is on the flywheel will show up whenever the light flashes on it.
I don't see what the problem is???
Ok ignore my post above as you wrote that while i was doing mine,I'm not waking around it they are showing up at timing pointer.
Very often just a resistance check will show up a faultYes I'm using a 12volt inductive timing light. Guess I'll see if I can figure out how to check timer base. But do u need a dva meter
