How do I disconnect the shift rod so I can drop the lower unit?
Grub54891 Admiral Joined Jun 17, 2012 Messages 6,464 Jun 13, 2016 #1 How do I disconnect the shift rod so I can drop the lower unit?
jakedaawg Rear Admiral Joined Jun 26, 2012 Messages 4,275 Jun 13, 2016 #2 Take off lower port engine cowl. You will the see shift rod connector and pin.
Grub54891 Admiral Joined Jun 17, 2012 Messages 6,464 Jun 13, 2016 #3 Will do Jake! I did try to look it up online, but came up empty. I thought about the lower cowl also, But thought they would not put it under there.
Grub54891 Admiral Joined Jun 17, 2012 Messages 6,464 Jun 15, 2016 #4 Thanks again, removed the port cowl, and there it was. Got it done in short order.
