HELP!!!
I bought a brand new Nissan 9.8 last Thanksgiving from www.onlineoutboards.com for the boat I just built. I launched the new boat last week. So far I have used the boat three times for a total of approx. 4 hours. I have been following the break-in procedure, and on the 1st trip the motor shut down after 15 min of operation while running a little below 1/2 throttle. It acted like it ran out of gas. The primer bulb was soft so I reprimed the bulb and after a couple of pulls it was running again. The same thing happened three more times within the 2 hours of the first trip. I went home checked the tank, pickup filter, in line fuel filter, fuel pump, carb, jets, fuel bowl and blew out the fuel line, all checked out to be clean. I went out for a second trip for one hour and everything went normal with no problems. Today I went out again for an hour and it was back to the same problem. When running at low speed it will turn off, when running at 3/4 it will pulse then shut down. 2/3 of the time the primer bulb is soft and 1/3 of the time of the shut downs it if firm. Motor always starts back up with 1-4 pulls. During the third and last trip today it shut down 4 times within an hour. I just can't figure it out!!!
