rsnyder518
Thread starter- Joined
- May 13, 2012
- 37
Glad I got a sailboat so I could sail back to the dock.
I brought a tank of fresh gas up to the boat this morning. Hooked it up and pumped the primer...but I couldn't get it hard. Usually it pumps up quickly, so this was weird. Out of curiosity I started the motor and all seemed fine. I gave the bulb a quick squeeze after it had been running for a few minutes and it seemed to have firmed up a bit. I figured it was a fluke (and maybe it was) so I left the dock and sailed for a few hours. At the end of the day I started the motor and it seemed normal. After a few minutes of motoring the motor just suddenly quit. I tried to restart it and it started back up but died almost immediately after putting it in gear. Then I couldn't get it to restart until I squeezed the bulb which was firm at this point. Then it started, ran and again died pretty quickly after putting it in gear. Got it started again, by squeezing the bulb. Thinking that maybe it was a fuel pump I tried to keep it running by squeezing the bulb but it didn't work. Even out of gear, it eventually stalled out...just not as quickly.
I'm a fanatic about gas. I had bad gas problems the first year I had this motor. But now I change the gas every 2 weeks, I use K100MG, I run it dry at the end of every outing, I clean the carb at the beginning of every season (4 hour soak + spray) and I use 91 octane. If this current problem is due to a dirty carb I'm going to be extremely disappointed because there is literally nothing else I can do to keep the carb clean. I don't think it's realistic that 3 weeks into the season it's already gummed up given that I totally cleaned it at the beginning of the season and have used fresh gas + stabilizer and have run it dry.
My gut feel says fuel pump issue, but not certain why I couldn't keep it running with pressure on the bulb. Thoughts, suggestions?
Thanks!
Thanks!
