Dave-R
Thread starter- Joined
- Mar 18, 2008
- 441
I finally got the right EGC for the engine. I plugged into the Rinda Diacom, and I have the following codes. SPN-29 FMi-3 ( TCP #2 Senser voltage high) . SPN- 697 FMi 5 (ECT gauge driver voltage low.) SPN-698 FMi 5 (Oil pressure gauge driver voltage low) and SPN 699-FMi-5 (Trim gauge driver voltage low) Any help on these. The engine cranks, but will not start. I hear the fuel pump relays and the pumps start for 10 seconds then shut off.the throttle body air valve also opens for 10 seconds then closes. The only gauge on the dash that is working is the depth finder. It is the only one hard wired from the ignition purple wire. I have a new throttle body installed, and I thought that was where the TCP senser #2 was. Help if you can. Dave-R
