Engine starts easily, sounds and runs really smooth. But after about a minute at half to full throttle it will bog down and sometimes stall out. After a few seconds it will usually pick back up and run fine again for a bit. Sometimes it repeats this again, other times it will run fine until you stop and start again. Feels like a fuel problem. Filters have been changed, so have the plugs, oil, air filter... I bypassed the onboard fuel tank, thinking it might be a clogged fuel pick-up, but no change. Obviously both fuel pumps work, at least most of the time. I'm starting to wonder if there isn't an intermittent problem with the float switch inside the FSM. Since it is intermittent though, I am not sure if the problem would be evident if I removed it and tested it, and they are expensive to change just on a hunch.
Any thoughts/input would be appreciated. Thanks!
