2011 Bentley 200 cruise 60bigfoot. Rpm's ??????
Bamaman1
Re: 2011 Bentley 200 cruise 60bigfoot. Rpm's ??????
If the selling dealership is not attentive to your concerns, don't hesitate to call customer service @ Bentley Encore in Lexington, SC--(803) 520-5280. Manufacturers often can tell owners the preferred propeller sizes and mounting heights for the engines. You should make sure you know the exact model number of your boat AND motor.
Bblakewv
Is there a diff in 14X11 props ?
Which one should I buy for my mercury 60bigfoot
Jeep Man
Mercury Black Max 77338A33 has been the stock prop on both my 60 bigfoot motors 14x11. WOT RPMs is 5800
Bblakewv
What is a 14X11 77338A45??
That's all I can find how is it diff ?!?
Silvertip
14 inches n diameter and 11 inches of pitch. You currently have a 13-3/4 x 15. The 14 x 11 is likely a pontoon/workboat prop whereas the current prop is for a planing hull.
RustyShackleford
I dont know about your boat size, but I have a 22' with a 60HP BigFoot and I can twist up to about 5500RPM. I dont know much about props, but I believe my dealer told me he gave me a 9.
Bblakewv
It's a 20ft Bentley ... I did raise the motor two notches And that solved the water splashing back deck prob. But still need to re prop to get in correct wot rpm's
Bblakewv
Silver tip. I've been given a merc. Number. That I can't find. I can find a black max 14X11 just not the part number that was suggested. Asked the diff.
Thanks
Bblakewv
Been looking for that .....
Thanks. Wish someone near me had a couple diff props (14X9 14X11). To try. Before I drop 150.
sirket
This really isn't something you should be paying for. It sounds like the dealer did not set up the motor correctly for you. They should fix that- not you.
RustyShackleford
Looked at mine today. it's 14x11.
22' party barge 60HP.
Bblakewv
What is ur top speed. And do you ever pull a tube. Thanks for ur time. Rusty.
After raising my motor. My top wot rpm's is 4500 tops.
RustyShackleford
I am actually going out tomorrow and planning on clocking it with GPS for the first time. I will let you know the speed and confirm WOT RPM.
Havent pulled a tube, but I might in the future. I think I am mid 20's MPH.
RustyShackleford
WOT was 5200RPM. With about 1100lbs of guys and gear that was good for 17MPH.
Water temp was 72deg.
Silvertip
Was that load what you would consider "average". You should be doing your testing with what you consider an average load (the way the boat will be loaded MOST of the time). If you prop for a maximum load the engine will overrev with a light load. If you prop for an average load the engine will be happier most of the time, recognizing that you will load it up periodically.
RustyShackleford
900-1100 lbs should be very consistent for me. It will go faster when it's just my wife, myself, and our two little ones, but we will almost always have someone else with us too.
