2011 Mercury 90hp 4 stroke EFI cuts out
Kongfish
ok,
Heres my issue, but first, here is the information about the motor so you will know better how to ID the problem.
I bought a 2011 90 hp 4 stroke EFI used but in good condition.
Just to be on the safe side I replaced the air filter, plugs, oil's, fuel filter on the high pressure side, new fuel lines, etc...( I did not replace the power packs or coils)
The motor(serial 1B853167) is installed on a Brand NEW 25 foot boat with new Everything.
New Prop Turning Point;# (LE1/LE2-13.25 x 17) HUB kit # 501
My issue is this; When i take off the GPS shows I am only getting up to a speed of 18 knots, it wont even plain out.
motor cranks and runs with a chop in it, but it will stay cranked in neutral all day long.
Also, when I pull back on the throttle the engine dies every time. even when i am barley in gear and going. anytime i am in gear and back off the throttle the motor turns off.
one other possibly related issue i am having is that when the motor cuts off, in gear, while moving, I am hearing a clicking from the lower unit area of the motor after the engine has cut off and is floating forward in gear.
