2011 optimax 125 water pressure hose
manctil
I have almost removed all my hairs. What is the water pressure tube for coiled up inside the motor. It appears it has nothing to do with a water pressure gauge. What is this hose for?
Don S
Re: 2011 optimax 125 water pressure hose
If it goes down to the lower unit, it's for the speedometer.
Don S
It's for a water pressure gauge, look at pages 140 and 142.
manctil
Don, with all due respect, you can blow right through the tube with it running or not, there is no connection to any type of water of any kind. It attaches to a sensor with 2 or 3 wires on it. It appears to do nothing. I will try and contact mercury, thanks for your help. I just spoke with a MAster Dealer and they don't know
Fun Times
Does your boat use smartcraft gauges? If so, does the digital speedometer work? Or do you have an conventional (analog) speedometer that works?
Also, if you do have the smartcraft gauge, then it's possible you may already have a digital water pressure readout on the smartcraft gauge.
The sensor should convert the water pressure it sees into a digital readout on the smartcraft gauge whether it be for a speedometer or water pressure gauge readout that can be used with the smartcraft system.
Now that gray coiled up hose would be for a water pressure gauge that should originally be set up for a digital gauge. There is a kit you could buy to set the gray hose up for analog water pressure gauge. (Quicksilver hose assembly # 32-892156A01, contains the necessary tubing, tee fitting and instruction sheet to allow the use of a 15 PSI Analog Water Pressure Gauge with the otherwise digital 1.5L OptiMax outboard.),
32-892156A01 | eBay
Tip for you if interested, if you'd like to learn a little more about an item your interested in with quality photos most of the time, try inputting just about "any" part numbers you ever come across in life into the ebay search engine like I did above. Usually you can find some info with quality photos to see what your inquiring about. Here are a few items you may need to inquire about for this project,
http://www.mercruiserparts.com/Show...NOIMAGE&inbr=14475&bnbr=315&bdesc=Accessories
22‑859731,
22
To help give you an idea of what i'm trying to say here, please have a look on page 1D-9, it should help explain it better,
http://1manual.com/Mercury manuals/Service Manual PDFs/OptiMax/859494r1/1d.pdf
