2012 250 EFI Mercury making an intermittent Whistling sound
3esso
HI there,
I got my 2012 250 2 Stroke EFI as a 2nd Hand outboard (which I know it might not be wise)
now the Motor had its issues before the mechanic finished installing it to my Hydra Sport CC while doing sea trails
When we took the Boat out the first time & after running for approx 15 minutes to the CG check point we noted the motor making sort of whistling Sound, but no warning sound/beep came from the Controller,
I took a look at the Tell tale just in case water wasn't cooling the motor (as initially the Motor would always give continues Overheating Warning - this is one of the issues mentioned before)
but water was streaming fine from there, after registering we decided to carry on, the whistling did not stop immediately, but after a while it stopped, then returned,
now we are on the 3rd time out on the water & the sound still comes & goes,
actual description of the sound is like a breezy wind on a not correctly sealed car window while on the move.
can anybody help Identifying this
