2012 3.0 Mercruiser how to check and set timing
Prophammer
I have a 2012 Bayliner with 3.0 Tks mercruiser , it runs fine in every way but it diesels when I shut it off , I would like to check the timing and see if it could be off a little bit, what steps are involved checking the timing?
Serial Numbers are always best to start with, if your serial number is above 0L341xxx
Then timing is 2 ATDC
Should have EST distributor
Click image for larger version  Name:	EST Timing.jpg Views:	8 Size:	47.7 KB ID:	10825332
jtsvette
The timing mark on the crank pulley can be difficult to see. It's just a little notch, you'd be wise to put a dab of orange or white paint on it.
