2012 60hp Efi bigfoot water pump question
dmoriarty51
Hey guys I replaced the water pump in my 2012 60hp Bigfoot 4 stroke and the pee stream seems odd.. Last season I had a nice solid stream like every other motor has had. Now coming out for the first day after the impeller replacement the pee stream is more of an aerated spray. The faster you run the motor the more aerated it becomes. Water pressure gauge reads roughly 3-4lbs idling and maybe 10-12 max as you get to full throttle rpms. I do not have water pressure numbers from last year because I did not have a gauge at that time.
We took everything apart just to make sure I didn't misplace a gasket or something but it all looked correct, Am I worried about nothing?
