2012 F115 with jumpy tach
WaterDR
I have a pontoon with a yam F115, 2012. The tach is very jumpy but the actual engine toms does not change. Tapping the glass on the guage can either cause it to jump or stop it from jumping. Any tips on what I can do to fix?
robert graham
Probably loose and/or corroded wires/connections on the back of tachometer.....need to remove each one, clean, grease, tighten....also check same for in-line fuses to the tachometer....
WaterDR
Thanks Bud! Sorry....I have not been on here in a long while. I don't see anything wrong with the connections. Its a plug-type. Its seems that when I remove the plug and plug back in....it works for a while but then starts acting dumb again.
WaterDR
99yam40
if unplugging and plugging back on helps for a little while,
then that connector could be where the bad connection is located. clean and lubricate
some tachs have switches for setting them for proper motor,
you might try switching them back and forth a few times to clean the internal connections
robert graham
Most any grease will do....heck, I've used a Chapstick plenty of times....just something to keep the moisture off those metal contacts....
