111torrance111
Thread starter- Joined
- Jan 8, 2006
- 275
2012 BF15D3SHS 15 HP Honda with a tiller setup, the motor doesn't pee hardly at all at Idle, when I give it some throttle it pees pretty good. The motor doesn't seem to overheat and will run fine.
Today I changed the Water Impeller and nothing change, while I had the lower unit off I checked the water tube and it looked clear (No Salt build up or anything in the tube) I also removed the hose that connects the housing (Pee Hole)
What can I check next?
Thanks/Jerry
Thanks/Jerry
