2012 Starcraft Limited 2000 I/O Question
clarsu7
I am the 2nd owner and do not have the owners manual. I need the engine and gear ratio specs to get a new propeller. Does anyone happen to know the stock gear ratio? I think my boat has the Mercury Alpha 4.3L MCT engine.
clarsu7
dubs283
MCT? mercruiser model designations are MCM, MIE and EC
most, but not all 4.3 liter engines use a 1.62 drive ratio. the ratio should also be printed next to the drive serial number located on the port side of the driveshaft (upper) housing
post your engine and drive serial numbers, those with access can tell you more info
achris
More fish than mountain goat
... I need the engine and gear ratio specs to get a new propeller....
No you don't... All you need is the pitch of the current propeller and what the revs are, with a normal load, at full throttle with that propeller.
With just those 2 pieces of information you will know what you need to get a new prop.
Chris...
Scott06
Willing to bet if it is a carburated 190 hp you have a 1.81 drive, if you have an mpi a 1.62 drive but chris is right before you go prop buying whats your current prop design (aluminum or stainless 3 or 4 blade) and pitch plus current wot rpm. Are you looking for a replacement or to solve an issue like better holeshot ?
