This is on a 2013 Harris Pontoon boat. Have been using all summer without a issue. Go to start today and will crank with no problem but will not start. Where should I start looking? Thanks in advance.
Good to have a spark tester in the toolbox. Then we can determine whether we're chasing fuel issues or ignition circuit issues. Checking Killswitch and fuses are good places to start. Followed by faztbullets advice and clean the fuel filter. Try dripping some good fuel into the carb and see if it'll start for a second on that
Battery. These new things won’t even try to power up the ignition and sensor systems when you’re cranking…unless the battery is tip top. Despite the cranking seemingly healthy
