FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Look where the PCM and relays are. There will be mini fuses (item 15) and will be covered with a cap. Its showing 2 - 15amp and 3 - 20 amp. The fuel pump will be 15. Check all the fuses
The main power relay turns ON first before the PCM will turn ON the FP
I checked the wires that power the fuel pump and found wasn't getting any power. some corrosion on wires cleaned and now my relay is clicking. I hear the fuel pump come on now foe a few seconds when I turn the key on.
couple of issues still.
engine still won't fire. it seems like its it almost catches but it doesn't.
also when I move some of the wires on the fuel pump and when I turn the key in the on position the fuel pump doesn't engage. I move the wires around and it engages.
Measure power at the relay and find out if pin 86 (green wire) goes to ground when key is turned ON. After pump turns OFF there should be 12V on the pin
