GhostriderL76
Thread starter- Joined
- Dec 22, 2023
- 10
Helping my friend get his boat he purchased last year sea worthy. He had it out a few times, both ending in issues. First the gear oil resevoir leaked and set of an alarm. Would this cause the engine to go into limp mode! New reservoir installed.
Second issue, low voltage. Diagnosed as alternator, most likely damaged when the gear oil leaked and coated the alternator. Replaced alternator. Have not yet run engine to test. Would the engine run poorly or quit, absent a solid 12+ volts? I'm wondering if he ran the battery down (inop alternator) and the ECM/PCM etc didnt like low voltage?
Third issue, we changed the oil, (suction pump) and the first quart was all water. 4+quarts of oil came out. So, where did the water come from? Last time the boat was out, the engine quit (low voltage?). Engine would crank, but not start. I'm wondering if the water came in the exhaust from the rear wake via absent exhaust baffles? Why no restart?
I wasn't there for any of this, so it's the best explanation I got / can give. The boat is in Phoenix soma frozen and cracked block probably isn't the reason for the water.
Thanks for the help
Thanks for the help
