2016 Mercruiser 4.5L - 6 Warning Beeps?
Status
Not open for further replies.
jwdavis28
I've googled it and looked in my manual. Can't find the answer. Haven't called the dealership yet as they are closed until tomorrow.
This is a new boat and engine with about 20 hours on it total. The 6 warning beeps will occur when idling up to cruising speeds. None of the gauges show anywhere near an issue and the engine warning light does not come on. All the fluids have been checked and are with the proper levels. Boat shows no signs of an issue at all.
Any ideas?
jwdavis28
I've been searching some more and am finding references to it being a drive oil alarm. It looks like it's at the right level but will check again.
Still appreciate if anybody else has input.
Thanks.
jwdavis28
It was the drive oil reservoir that was low. I called the mechanic and he said it could be about 6 different things but to start there. Fixed.
Starstep
Do you still remember the other issues your mechanic mentioned to you, I have the 200 hp 4.5 and it has the same issue but no one seems to have the right answer so now it’s just try this and try that!!
GA_Boater
The OP has been gone over 3 years.
Closed.
Status
