2016 Yamaha VF115hp lifting points?
thyNemesis
I am in need of a solution to help support my engine whilst I install a -sandwich style- Minn-kota Talon shallow water anchor.
This bracket sandwiches between the transom and the engine bracket.
I am planning on loosening up the bolts, not removing all of them at the same time but enough to move the engine back away from the transom about .75"
so I can insert the bracket in between the transom and the engine bracket, reinsert the removed bolts and them proceed to the other side to do the samething
with installing the required shim.
I couldn't see any lift points on this engine.
Any ideas on how to use a cherry picker to help support the engine during the install?
Thanks.
Don't know about your Yam, but I lifted mine by using to straps and tying them with another line at the bottom so then are held in place. Similar to this pic below but they are just using rope.
Here one which can buy but should give you the idea of how
Then this one was done by a member here
