2017 Bennington SL20 w/ F70LA Outboard Algae issue!
ApexEagle2027
Hello,
I recently purchased a 2017 Bennington 20SL pontoon boat equipped with a Yamaha F70LA outboard engine.
I've noticed a hard, brown/mustard-colored substance accumulated on the exterior of the engine. I've attached several photos for reference, is this possibly mineral/iron/tannin deposits mixed with dried algae?
According to the previous two owners, the pontoon was used exclusively in freshwater lakes and rivers and was never operated in saltwater.
Based on the photos, I'm hoping you can help identify what this substance might be, what may have caused it, and, most importantly, recommend the best way to safely clean and remove it from the engine's exterior without damaging the finish or any components.
I would appreciate any recommendations for specific cleaning products or chemicals that would be effective for removing this type of buildup.
Thank you for your time and assistance. I look forward to hearing your recommendations.
looks like mineral deposits.
are you boating in a high mineral lake? the spring-fed lake my bud lives on in Wisconsin has similar deposits from the limestone bedrock
any hull cleaner or toilet bowl cleaner containing oxalic acid will clean that. anything with citric acid may also clean it.
ApexEagle2027
Previous own stated to me 95% of it's life was at a marina in Northampton Massachusetts river water, but I will look into a oxalic acid as you mention and in the spring give her a cleaning, thank you for your input.
I would not wait until spring, you will need to use a jack hammer if that stuff dries out and hardens
It will take you a few hours now, or days in spring
