baconfudge
Thread starter- Joined
- Jun 21, 2020
- 38
got boat couple weeks ago, been out twice. been reading forums and watching every video i can on porpoise/trim/throttle and new boat owner but family has had bass boats my whole life, been on lakes enough to understand what should be happening and my boat..isn't it.
so stopped or idle, trim all down (tested in driveway motor goes all the way down) i throttle forward quickly to about 75%, rpm will hit 3500ish and bow rises a normal amount and boat planes out, id say 4-6s before bow starts to drop, rpm increase which is normal then the circus starts. boats going around 20-25 mph and i have to pull back on throttle or seemingly break the haul in half. i dont even have a chance to trim up, when ive tested trim up it gets even worse porpoise. ive tried starting at diff trim levels, all it does really is put the bow higher on launch, take longer to plane and when i get there it major porpoise, i can trim back then but doesn't stop it, have to throttle back. only thing im afraid to try is to add more throttle and maybe push thru it and work the trim but it's such bad slamming i dont know if i'd have control of the boat if i pushed the throttle more.
i really want to convey how bad it is, im watching other boats go past on plane with little or no porpoise, im watching these videos on trim they get on plane, more thottle, trim up, get more speed, then the porpoise starts and they trim down a little and it stops, its like a 5-10 degree porpoise, my boat is like 45 degrees, slamming.
so i guess in short, i don't believe it's operator error as far as throttle and trim or water conditions, ive tried different combinations, even ones i know are wrong like launching at 1/2 trim up and it's same results. the only time it runs anywhere close to good is when im barely barely barely on plane and maybe 20mph and really working the throttle to keep it in this very very narrow sweet spot, and trim up, forget it, when i barely get in the sweet spot it i even but up trim barely its slamming time. in that sweet spot i either pull throttle back to much to stop porpoise and come off plane or to much and slamming time.
conditions: somewhat interesting and maybe obvious is trip 1 to lake i had me,gf, parents, daughter and d-bf. about 1300 lbs. with heavy people in chairs and on bench and kids in front it was a struggle to get on plane, to much weight in back, so switched mom and gf and dad to front and could get on plane but it was porpoise but not as bad as trip 2. we did tube and w/ 4 in boat and 2 kids on tube i was running in that sweet spot a little easier and wasnt trying to push the speed plus the turning and working the throttle the slamming wasn't bad. trip 2. just me and gf this is where the porpoise really shines from above 3 paragraph description. we are about 500lb combined, both sitting in chairs.
so..here's what ive learned trying to figure out the issue. please comment and correct me if I'm wrong or totally missing something, i am a new boat owner so just learning as much as i can.
1. i have a 18' boat with a v6 and swim platform creating stern weight which is the cause of the porpoise.
2. the boat isn't loaded down, have some life jackets and the deflated tube under rear bench. a cooler thats maybe 20lbs. then me and the gf.
3. trim tabs can fix porpoise on some boats and really have no negetive effects besides maybe?? lower top end speed, well my top in on slammer jammer is 20mph so not worried about top end speed now.
4. hydrofoil not as good a trim tabs for porpoise, maybe as good for getting boat on plane (getting on plane isn't issue, 220hp merc pushes it up on plane w/ me and gf, it's after on plane is the circus.
5. boat could have some type of hook or eh forget other term but basically the bottom of the boat has some type of defect, i took an old license plate (didnt have ruler) and laid under the boat and put edge along bottom, it was mostly flat but a few places i could rock the plate maybe 1/16" to 1/8", havent found allot of info on what is normal and what is a problem if anybody could explain in terms of testing what is bad id appreciate it as ive read several times that these hooks cause cause the porpoise im seeing.
6. boat could be waterlogged? there is a scale at a pilot gas station up the road, getting app and im going to weigh it to rule that out as causing more stern weight than there should be. its a 2017, its really clean and no water in engine compartment and i got from dealer so im not optimistic that is the cause.
7. prop: talk about confusing, i have 3 blade 14.5 x 19, i did notice the little trim fin above the prop isnt there and there is a round plate instead, ive read this doenst affect anything but not sure if glastron comes that way or maybe previous owner took it off to put this prop on and not hit it. so i think i understand the diameter obviously, the 19 how fast it moves forward but the rake seems to be the factor in bow rise or stern rise, i think i have the rake that is stern rise now and its progressive (twisted) fins so i don't know enough about the prop or what props do to know if it's causing or contributing to the porpoise. seems like rake should be a spec but when i did the merc prop finder deal it gave me some prop options (they were x21 and x23 also) but didnt even list a rake spec so i don't even know how to compare mine to another as far as rake.
8. glastron is just a crap boat? i figure every boat manufacturer has some markerting thing, glastron is ssv haul tech that gets on plane quicker, seems great glastron, except when im on plane i rattle my teeth out so is this a glastron issue? not much on glastrons on the google. i was drooling a little at 220hp but maybe thats just to big of a motor for 18' boats?
9. use, id like to put the boat in the water, drive fast and smooth around the lake abit, stop and swim at boaters beach, maybe pull a tube around for abit and have a fun boating day, nothing crazy, i just don't want to porpoise across the lake like im riding over 5' whitecaps. also other boat wake i just thottle down thru them then quick back to plane and try to find sweet spot, there's no running thru even very modest boat wake w/out pretty much a pancake slam.
10. idles fine, have to correct steering whole time in no wake zone but no known issues going slow. boat seems to be level at idle which i find maybe odd id think the stern would be lower w/ all the stern weight. also we anchor at boaters beach, boat seems to be sitting in water level when anchored.
so i guess that's my situation and summary of what i've learned about it, any other info/test/examples would be appreciated.
