2017 Mercury 8hp outboard
ricovw
Hi All,
I have a question for you. I had found water in the lower gearcase. So I bought all new seals and took the lower gear case apart. When I pulled out the carrier, the cam follower fell out and I didn't notice if there was anything behind the cam follower. I replaced the seals and put it back together and now I don't have neutral or reverse. I took it apart and realized there must be something like a spring that goes behind the cam follower. I've looked on the drawings but it doesn't show anything there. There is a spring but it is on the other side of the retaining pin that moves the drive dog. Or maybe I missed a step on the re-install? Any insight would be great, thank you!
