wvmedic
- Joined
- Jun 3, 2008
- 545
Hello all, I have a 2019 F25 SWHC Yamaha 6FMK S. I have recently replaced the Impeller, not the kit, just the Impeller. After changing the Impeller the temp light come on at an idle in gear, seems to go into limp mode. I do a lot of trolling and haven't had an issue until now. The tell tale seems weak at idle and WOT, it has since new, that is in comparison to the old Evinrudes I've ran. I have ordered a thermostat and a water pump kit for it. The housing and plate looked good, no scoring on the original when I replaced the Impeller. The Impeller was an aftermarket not OEM Yamaha though. I have removed the thermostat and ran it without and still have the light come on at idle. I flushed the motor with the thermostat out and it flushed good, no corrosion that I can see anywhere. I might have 200 hours on the motor and has always been in fresh water. Does this motor have a poppet valve? Any ideas what the issue could be? I don't have a manual yet, I know I need one. I have no idea how to test the temp sensor with that being said.
Any suggestions will be appreciated.
Thank you, Jeff
Thank you, Jeff
