2019 suzuki 20hp alarm
brian3127
how do you check the codes on these engines.
we were running it yesterday and the red light was on and horn was beeping.
it was running really rough when it did this.
oil on the dipstick is good and it has a good pee stream.
brian3127
took the boat out yesterday. motor ran like crap. could see a rainbow in the water. thinking gas. no buzzer though. Any ideas?.
99yam40
possibly overheated and warped the head.
check plugs for signs of water, do a compression check or leakdown test on the cylinders
brian3127
there was a pee stream so im thinking its not overheated. but i will check compression. What should the numbers be for compression.
matt167
The diagnostic software and cable is relatively cheap. Find it plenty of places. Last I checked it was under $100. This will give you codes and live data as well as the ECU tracked engine hours
brian3127
can you give me the name of the cable and the software.
matt167
That appears to be correct. It is an aftermarket cable and probably ripped off software but it may very well work. The real deal is around $200 now and is genuine Suzuki
matt167
I can’t get a link to display. Amazon does list the OEM Suzuki SDS
