2020 Suzuki DF70A Fuel Problem
JohnsonDW
I'm getting fuel to the low pressure fuel pump and it is working fine. I'm not getting fuel to the injectors fuel rail. What can I check without having to remove the manifold to get to the vst? Motor has less than 50 hours on it. I did have some bad fuel. I replaced it and changed the water separator filter. Drained the vst and the filter ahead of the low pressure pump. Any help will be greatly appreciated.
